1 members (1 invisible),
105
3
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Tool;
Are you sure you are dealing with a 350 or small block? Some early 366/427 tall decks had the square pump drive for the distributor. If you have changed the pump and drive, did you change to a slotted drive? If so, just take a screwdriver and turn the pump drive to line up with the distributor when you drop it in. Do you have a pic of the engine? That will clear up a lot of questions. Also the 366/427 tall decks have a longer distributor shaft to make up the difference in the deck dimensions. Good luck.
SimS | | | |
Entire Thread
1969 C50, HEI distributor upgrade.
| tool | 12/02/2013 8:35 AM |
Re: 1969 C50, HEI distributor upgrade.
| Wrenchbender Ret. | 12/02/2013 4:36 PM |
| tool | 12/02/2013 7:29 PM |
| don stocker | 12/02/2013 5:57 PM |
| tool | 12/02/2013 7:39 PM |
| baldeagle | 12/02/2013 7:53 PM |
| tool | 12/02/2013 8:18 PM |
| don stocker | 12/02/2013 8:37 PM |
| tool | 12/02/2013 9:15 PM |
| SimS | 12/02/2013 11:19 PM |
| tool | 12/02/2013 11:36 PM |
| don stocker | 12/02/2013 11:52 PM |
| tool | 12/03/2013 12:07 AM |
| tool | 12/05/2013 1:03 AM |
| SimS | 12/05/2013 12:19 PM |
| mrolds88 | 12/05/2013 7:27 AM |
| Wrenchbender Ret. | 12/05/2013 4:46 PM |
| lcc123 | 11/02/2025 10:05 PM |
| Hotrod Lincoln | 11/03/2025 5:01 PM |
| Rich'sToys | 11/04/2025 4:56 AM | |
