Dads 50;
By looking at your pics I think I have a Bendix brake setup. Whats confusing me is the rear wheel cyl that I have. They are the ones with the threads on both ends. Does the rear bendix cyl. have the threads? if not, could I use the my cyl. with the rubber boots? My cyl have a 1" bore. Your pics don't show the rear brakes from the inside, only the back side. What rear cyl. did you use? Does it have the rubber boots or the metal adjusters?
