8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny),
153
2
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I found a bent push rod on #1 intake of my 216. After doing a search here the problem was old gas that allowed the engine to start and run but varnish seized the valve after sitting up for a week. I did the 50/50 acetone and Marvel Mystery Oil on the valve and lightly tapped the valve to break it loose. It was still SLOW to return to the top when I turned the engine over by hand so I put a halogen work light on the valve to warm it up. That did the trick. After a new push rod & a few more revolutions to assure it was returning to position I got the engine started with fresh gas and now back on the road again. Hope this helps someone else. | | |
