look thru the engine and driveline forum, folks recommend a variety of techniques, but what I'd do if it turns well by hand, is disconnect the coil to distributor lead, pull the plugs, squirt a shot of oil in each cylinder, crank it for a minute or 2, reconnect the electrics and give it a try
