Up to 1940 there was a factory reducer, similar to what Tim linked to, only it was slightly taller.
What year is the engine? You do not want to use a 1940 head on a 1941 or later engine. 1940 was the last year to use dome pistons. If you use a 1940 head on a 1941 or later engine you will have very low compression.
My Blog
