1 members (texczech),
51
2
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Your carb has a bad accelerator pump. Dried out, not sealing. http://www.autozone.com/autozone/ac...-1826/_/N-25vm?itemIdentifier=10722_0_0_Edelbrock 1405 is a good carb, (carter AFB). Easy to rebuild, two piece. You are almost there. Adding to what VEW said: Bad gas will ruin a carb AND an engine. Hope you cleaned that tank real good. Filter can let "varnish" thru. Change fuel filter every 50-100 miles a few times.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
