This is probably a stupid question, but when you say you made attemepts to start your engine, did you pour gas down the throat of the carb?
Victor
~ Victor
1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery
1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD
1957 3100 - moved on
1959 C4500 Short Bus "Magic Bus" - moved on
1959 G3800 1 Ton Dually "Chief" - moved on
1958 C4400 Viking "Thor" ~ moved on to fellow Bolter
