| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 39 New Guy | | New Guy Joined: Feb 2011 Posts: 39 | Have installed a 14 bolt rear in my 50 3/4t flatbed. Now it's time to figure out the p brake. The rear has the cables from the dOnor truck still attached but they are much longer and are set up to pull from one side. Before I get started do any of you know a straight forward solution?
Also on a separate note the cpp brake booster kit I got ain't holding pressure. bled everything, no leaks, get pressure on the pedal and truck brakes. after it sits have to pump it up again to build up pressure. Would appreciate a tip took it to the shop for the first time to get it bled and now its in a bay leaking cash. Thanks Aubrey | | |
