Did the crank bind when you tightened it? I would leave the rear main seal out and use plenty of assembly lube on the bearings. Slowly tighten the main caps and make sure the crank turns free. If you get things tightened to the recommended torque spec and it is still free I would then plasti gauge and see if you are going to need shims.
