I used Jim Carters set up on my "52" 3100 and it worked perfect. The filler came out so it just missed the front bed stake. I installed a "48" cab on my "52" so there was no gas tank in the cab. The Jim Carter tank and bracket is just a replacement for a original under bed tank. This looks to me to be a much safer location then behind the rear axle as many under bed tanks are.
