| | | Forums66 Topics128,168 Posts1,057,027 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It depends on the brand of tire. They're both 70 ratio tires, while the 255's are wider than the 215's. The diameter (height) doesn't necessarily change with the change in width. As for whether the 255's will fit the wheel well, I couldn't say. I have 235's on my '48 and they're fine. You haven't said what truck you have... 255/70/15 is a size measurement. Every tire of that size will be the same height and width, regardless of brand. Same with 215/70/15, etc. There may be slight differences depending on tread design, but that's it. | | |
