| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | If one wheel is still on the ground, the spider gears will double the gear ratio. The best way to get an accurate ratio check is to count the teeth on the ring gear, and divide that number by the pinion teeth.
Example: Ring gear-37 teeth Pinion gear-10 teeth Gear ratio-37 divided by 10=3.70:1
