| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Here's an article that explains how a fuel gauge works - http://auto.howstuffworks.com/fuel-gauge1.htmRead it. You can do a very simple test to verify that the gauge works. Disconnect the wire that goes to the fuel tank. The gauge should read empty, because you have maximum resistance (infinite). Connect the terminal to ground. The gauge should read full, because you have minimum resistance (zero). If it doesn't, the gauge is defective. | | |
