| | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | just ran out to look. Carb is about an inch and a half away from the doghouse. Then it has an s shaped tube mounted on it with the oil bath air filter to top it all off. When the hood is closed it just about touches the air filter. It sounds like your carb will hit if the engine is straight ? | | |
