Thanks for the info!!!
The Other "interesting items" were part of the truck's hydraulic system which was used to operate a dump bed. The plate was the mount for a belt driven pump. The bent rod over the plate was a control rod for the hyd. valve. On the fire wall you can see a black box which was the Hyd. reservoir.
