I got my stainless brake line set from inline tube.
The rear brake lines where reproduced from a crappy example I bent up by hand (I needed a custom set because of my 1982 3/4 brake conversion on the rear axle). It looked like a child did it when I did it. InlineTube smoothed out the unintentional bends my lines had.
The ones I got back were very nice. The flaring on some of them wasn't that great, but stainless is also difficult to flare. I'm still alive and the lines don't leak, so all is well.
www.inlinetube.com.
They can reproduce any brake line you send them 1000 times and they will all be the same CNC bent.
They did a pretty good job. They were kind of tough to deal with though. In the end it worked out. BEWARE - open your box and make sure everything is there. If you are missing anything, they will charge you for it after a period of time.
It does say that all on the OUTSIDE of the box, so it's my fault even though I didn't know what was missing.
If I needed a set again, I wouldn't be opposed to dealing with them.
