| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Rocker nuts on a small block should be self locking type. You may have standard nuts and they will work loose. A set of new nuts would not be expensive. If there is enough stud above the nuts you could double nut them and lock them together. Are the nuts "rounded" at the bottom to match the rocker? If not do you have a rounded collar that matches the rocker? Take the time to give it a good look.
Steve H
