| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | herriot...what I did when trying to get hoses for my 49 was to get coat hangers or a stiff piece of wire and cut those to the lengths you need and bend to the configuration you need as well. also note the sizes of the ends you need....then I went to autozone and the guys at the counter let me go to the back and spend some time with the hoses...for the bottom I ended up buying a much larger hose and cutting just the portion out that I needed....found the bottom hose at autozone and top at o'reillys.....hope this helps................whid 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
