OK found this info...
'55-'62 flywheels use a ring gear with 168 teeth, and must be used in conjunction with a 12 volt starter. All 6 volt flywheels have 139 teeth on the ring gear.
You can use a flywheel from '55 - '62 model 6 cylinder engine...
i guess im counting teeth tomorrow...
