Winter is Coming
The stuff listed above is IF the column is for an automatic. IF it is a 3 speed column and your auto shift lever is on the floor (as most of these trucks were I6's w/ 3 speed Saginaws), then you're going aftermarket or putting in the correct column.
1967 Chevy truck "The Hurricane"
WARNING: This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
