1 members (Phak1),
84
2
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96501 07/27/2006 2:37 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yup.. that’s it, about 5/16” in diameter when the grease is removed. To run the wire I removed the steering wheel and un-clamped the column both at the bottom and below the dash. Then I slipped the column up the shaft until it hit the inside of the cab roof. After removing the old top bearing and cleaning the grease out of the bottom of the column I dropped a length of fishing line with a small weight down between the shaft and the column. Then I fished the line out through the correct hole and then pulled the wire through. If you need photos of the horn assembly I can pass along the ones that one of the guys here sent to me | | |
