0 members (),
100
3
Mod | | | Forums66 Topics128,194 Posts1,057,261 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The gear kit from Patrick's will only work in 1/2 tons. With the 3/4 and 1 ton stock rear, the 4.10 from the '68-'72 3/4 is the highest gear you'll find. Otherwise, a complete rear swap is in order for anything higher. A good source for a 3.55 gear would be to check under Dodge or Ford vans. That gear in a Dana 60 housing is very common, and the overall width is just right for an AD truck. Be aware, though, that many of these are semi float, rather than full float like the originals.
Bill Burmeister | | | |
Entire Thread
1953 3/4 ton,change rear end gears
| jeffw | 07/09/2013 9:33 AM |
Re: 1953 3/4 ton,change rear end gears
| 3B | 07/09/2013 10:37 AM |
| harryr | 07/09/2013 12:42 PM |
| Bruce Ioppinni | 07/10/2013 1:14 PM |
| EdPruss | 07/09/2013 2:39 PM |
| jeffw | 07/09/2013 4:05 PM |
| funtime | 08/14/2013 11:57 PM |
| Denny Graham | 08/15/2013 2:01 PM |
| Murraydave | 08/17/2013 9:42 PM |
| LONGBOX55 | 08/17/2013 10:45 PM |
| Denny Graham | 08/18/2013 1:17 PM | |
