you just need to find the length needed [use a piece of stiff wire shaped to the space] and get a hose of the larger size [1.75"], then get the adapter to bring one end down as required - likely you'll be getting one of the 'corrugated' flexible type, rather than finding one pre-shaped to your unique application
