| | | Forums66 Topics128,123 Posts1,056,653 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 'one hole facing the engine' is likely where the backmost bolt for the door hinge goes - the piece the fender bolts to is part of the pillar bottom, if it's totally gone, you're in trouble, it needs to be properly positioned - it's FFBR55L/R here, it's welded on - for rough idea, see lower right corner this picBill | | |
