| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well cowboy, hate to be the one to tell you this, but if you've disturbed that oil line then you're going to have to replace it from the oil distributor-thru the block-and up to the rocker arm shaft connector. The seal thru the water jacket is made up with compression fittings and once they are disturbed bout the only way to fix it is to replace the whole line.
I think most of us here have made that very same mistake of messing with that line before we discovered how it was installed.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
