And, don't forget the often forgot brake hoses. They may look fine from the outside, but they contract on the inside, and will not allow fluid to flow either way.
Victor
~ Victor
1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery
1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD
1957 3100 - moved on
1959 C4500 Short Bus "Magic Bus" - moved on
1959 G3800 1 Ton Dually "Chief" - moved on
1958 C4400 Viking "Thor" ~ moved on to fellow Bolter
