| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | Most likely, the brushes are gone. But rebuild it and it should be fine. Remember, it was designed to run on a lot of current. That would create some heat at the brush and commutator connection so clean up that as well. Shop manual covers it pretty well. No need to change the flywheel if the teeth are good and the clutch is good.
Steve H
