I had a local glass shop install the glass into the frames using polyeurethane caulking. Purchased a new center bar ( rubber preinstalled in stainless ) from Steeles after trying forever to get Jim Carter rock hard rubber into thin stainless trim. Also purchased rubber perimeter seal ( windshield frame to body ) from Steeles. Soft and pliable made it easy to install in " Tee " slot around frame. Cut to length and glue butt joint with 3M adhesive specified by Steeles.
