8 members (FrankenChevy, fonz8261, Peggy M, baldeagle, tclederman, TexasJim50, carbking, 1 invisible),
52
Mod | | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Flaming river column, Don't have the computer or harness at this time. Any suggestions on the harness? be sure to check the trans arm end compared to the shifter end and make sure the linkage is adjusted correctly from the park position and your neutral safety switch works as per Lokars instructions ... if it's an "E" what are you using for the computer? what column shift?
Bill | | |
