| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Tim, I'm a gear head so I understand cams, lift duration etc. I didn't understand what triangle was for. I see now that it's for checking timing gear wear, or to make sure the timing gears were installed correctly. "Thank you" for educating me with the link you posted.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
