| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Now that my Burb body (Skeleton) is back from the paint shop I have begun to put all the parts back in place. I hope to complete it in the next 4 months.
I have restored 3 Art Deco PU Trucks but the Burb is a different beast.
As I move through this restoration I will add to this thread.
Rule #1. Do not put the tailgate and lift gate on right away. The tailgate causes you to reach and stretch more than you should have to, and more importantly you are guaranteed numerous bumps and cuts on your head due to the sharp corners on the lift gate as you move around.
2. When fitting the new window channels fit the channel to the window then fit it into the wood frame. I first tried fitting the channel to the wood frame and it took twice as long as fitting the channel to the window glass. Regardless be prepared to pull the channels and windows numerous times.
Use small, #4 X 3/4 flat head count sunk screws to fix the new channels to the wood frame. Too large a screw will interfere with the glass as it moves up and down during the fitting process.
More to follow as I progress. | | | |
Entire Thread
Art Deco Burb Restoration What I am learning
| Murraydave | 07/15/2013 4:36 PM | |
