Found a late '40s frame, that is the leftovers of another person's S10 conversion. They lifted the cab off, and rolled the complete frame and drive train out from under it. New project will be titled as an S10.
I'm thinking of saving the complete old frame/running gear, and finding a cab for it at a later date, but want to make sure the paperwork is in order. Here's the question...was the late '40s engine serial number the same number as the serial number found on the door frame tag?
