I would look into the cause of the damage. I assume when you say connecting rods you are talking about pushrods. If cause not apparent then change out the broken parts, remove the spark plugs and turn the engine over several times by hand looking for interference. Parts you say are broken are not lightweight parts so if they broke something must be awry. Proceed slowly to avoid further damage.
