Your too close to quit now... Sounds like everything is there. Make sure your source of power is good, hook it up to the horn. hook your mast bearing wire to the horn. Take the horn button off the steering wheel and fabricate something to touch the steering shaft to ground. A wire with an aligator clip hooked to a good ground and touch the center of the shaft thats exposed at the steering wheel nut. Or hook a meter up to the mast bearing wire and the other to ground and check continuity when you push the horn button. Hope this helps.
