| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Sounds like a bad ground to me. I had the same thing with my '51 216. Found corrosion on frame to block ground strap. Cleaned it and problem was gone. Check all your grounds. This is a 6 volt system too. Hope this helps. Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
