0 members (),
90
6
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is true that Chevrolet did not use a rear seal until 1940. That said I would start by pulling the pan and checking main bearing clearances. If the rear main has too much clearance it can leak oil pressure/oil out faster than it can drain back into the pan. I would also make sure the drain back hole is not sludged up.
See the USA in your vintage Chevrolet! My Blog | | |
