see::
this little wire kit allows you to run a single filament bulb working as two bulbs.
SO
you can have a turn signal and brake light and they are the SAME BULB
Make #JE-SFL work like a double filament light with our wiring conversion!
One per light needed.
#L-JE01 Conversion for JE-SFL (each) $5.00
http://www.watsons-streetworks.com/other_lights.html
Jim & Caroline
The highway is for gamblers, better use your good sense."
Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
