1 members (baldeagle),
46
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are two grooves. The front one is to catch oil and return it back to the pan through the drain hole in the cap. The rear groove is where the seat goes. Wick/rope same same. Some disagree but I like Neoprene seals on an engine that does not use shims. If you decide to use a rope seal get a Best Gasket seal. They are easy to cut the ends. I would sure like to know how Fel-Pro for example expects you to cut theirs.
See the USA in your vintage Chevrolet! My Blog | | |
