| | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only transmission that will be a direct bolt in is the 1937-46 truck 3 speed, with the 1940-46 being the best. 1937-39 has straight cut gears for first and reverse so they are a little noisier. The 37 trans would also need a 1938-39 front bearing retainer for the throwout bearing to ride on. (1937 was the last year for the carbon throwout bearing). The only adapting would be to add washers/spacers between the trans and master cylinder mount as the 3 speed is narrower where the mount attaches to the side of the trans. The 3 speed is not synchronized in first gear, only second and third.
See the USA in your vintage Chevrolet! My Blog | | |
