| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94922 03/05/2006 3:22 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’m sitting here holding one in my hand. If your ’41 is like mine you can not see the clip from below . I’ll describe the process for mine.
Probably the easiest way to see it is to loosen the chrome trim ring on the front of the dash and allow the whole switch to roll over upside down. You will see a U” shaped metal tower that houses the dash light dimmer. The rod from the knob passes through this and then it passes though another “U” shaped bracket (facing the opposite direction) which is the slide for the switch itself. The spring clip is inside this second “U” and engages a slot in the rod. Push the spring clip toward the body of the switch and while you have it pushed all the way down into the switch body pull the rod and it will come right out. | | |
