| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not from a 'substance', simple result of tarping directly on the metal, condensation from our acidic atmosphere trapped and 'cooked' over time .... clean it well with a good brand 'wax and grease remover', sand it well, wax and grease remover again, prime and paint .... epoxy primer is best, but I'd get it all to bare metal for that
Bill | | | |
Entire Thread
Surface prep - acid, base, brake fluid?
| Teds58Panel | 06/07/2013 1:56 PM |
Re: Surface prep - acid, base, brake fluid?
| tclederman | 06/07/2013 2:30 PM |
| Flxible | 06/07/2013 2:49 PM |
| Teds58Panel | 06/07/2013 4:43 PM |
| Teds58Panel | 06/07/2013 8:37 PM | |
