Hey guys,
Helped a friend pull the 305 out of his silverado, and drop in a '71 402 we pulled out of a '73 truck. It was almost a bolt-in swap except for the d-shaft.
The 402 runs cool, has good oil pressure & doesn't smoke, but it has 50 PSI of compression on the #2 cylinder. We checked compression on #6 and it had 125 PSI.
Would this be valvetrain related? The only other thing I could think to mention is for some reason, the fuel pump pushrod isn't moving. So we used an electric fuel pump.
What do we need to look at?
thanks
chip
