1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As Tim mentioned you need to verify you have the bushing lock pins. They are in the top side of the torque tube covered by the U' joint bell. If it is an original 49 torque tube than it will have the lock pins. The Okie bushing number Patrick's should send you, if it has the lock pins, would be a M102.
See the USA in your vintage Chevrolet! My Blog | | |
