7 members (Maybellene, GMCJammer51, KEVINSKI, Hanks custodian, JW51, 66flea, 1 invisible),
63
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#9472 10/17/2002 11:11 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Did the mallory coil and distributor paperwork say anything about using a ballast resistor? It could be the coil or electronics overheating, loose/old wires, carb vapor lock, etc. Is your heat riser in the exhaust manifold working or stuck?
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
