9 members (66flea, Rosco, Dakota Bob, 1955 1 Series, Shaffer's1950, dt235sd, Otto Skorzeny, KEVINSKI, 1 invisible),
195
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,291 Posts1,058,588 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | This may be a red herring, but I will tell you about a problem I had with an old Volvo SW. I would make a right turn and it would stall. But being fuel injected with an electric pump it would suddenly start again. The fuel pickup line inside the tank was rusty - mainly from previous owners keeping the tank empty. So when I turned right, the rust hole in the pickup line would draw air. After a few minutes the fuel would cover the hole again and away I went.
I would check your pickup line inside the tank for holes or obstructions that could be a problem when the fuel moves around in the tank. I don't know what kind of strainer is on the pickup, but I also experienced a problem with a customer's car that had water in the tank. The water would block the intake screen. I doubt that is an issue but it might get the creative problem solving juices flowing.
All that being said, most experienced techs will tell you it is almost always the most obvious thing e.g. the float needle.
Entire Thread
I'm stumped...carb?, fuel pump?, other?.... any ideas???
| hardcrab | 05/18/2013 5:42 PM |
Re: I'm stumped...carb?, fuel pump?, other?.... any ideas???
| Steve_H | 05/18/2013 6:03 PM |
| hardcrab | 05/18/2013 6:12 PM |
| Steve_H | 05/18/2013 6:19 PM |
| Jim Sears | 05/18/2013 11:09 PM |
| carbking | 05/19/2013 8:00 AM |
| don stocker | 05/19/2013 8:10 AM |
| hardcrab | 05/19/2013 8:20 AM |
| hardcrab | 05/19/2013 8:12 AM |
| Anzan | 05/25/2013 11:48 AM |
| sstock | 05/25/2013 12:08 PM |
| brokenhead | 05/25/2013 1:45 PM |
| oldbluetruck | 05/26/2013 1:00 PM |
| Teds58Panel | 05/31/2013 7:38 PM | |
