| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | I've hummed and hawed on this idea for years and finally took the plunge. I know I know "cutting up a classic" but it's mine right? Wasn't easy but in the end works out very well. The ccp kit for the firewall hangs so the old clutch had to go as well. Had to fabricate a hanging petal and get everything perfect in a VERY tight space. Funny you can land a plane on these firewalls but everything wants to be in the same place. In the second picture you can see a blurry bolt. That bolt is now in place to act as the stop for the ebrake handle. Had to readjust it and the cable in order for it to clear the petal. Also needed a new clutch plate from a 283 vette to work the hydro correctly. New brake lines throughout, roller bearings etc. So overall these aftermarket "all inclusive" kits are far from that but with time and thought work out well. With new carpet installed the end result is a nice one. Since I fabricated the petal assembly I was able to work with the distance and pressures needed so it still "feels" like a bolt. But let me tell ya don't throw a dime in front of me unless you wanna see my truck as it STOPS! Now. Nicer then ever before anyway. Enough of my rant. Just wanted to share. photobucket photobucket photobucket
