9 members (frogfarmer, 66flea, DoubleB, moparguy, ShopRag, Bill Hanlon, Wheelie, Dakota Bob, 1955 1 Series),
189
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,292 Posts1,058,590 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | Thanks, guys!!! I'll check all these scenarios out and see what I can find. I thought about the tank vent, even took the gas cap off while waiting on the tow truck- it still didn't pump fuel. Would it take a while to equalize pressure (vacuum) before it would pump?
Also- now that I have the electric pump, is it any problem to just leave the old mechanical pump attached to the block pumping air, or should I remove it and get a cover plate? I tried to use both the pumps in tandem but the elec. pump wouldn't pump through the mechanical pump if the engine wasn't running.
Edit: thinking about the vacuum issue- when I took the fuel hose loose between the tank and pump, while sitting on the side of the road, there was plenty of fuel flow to the pump via gravity. The pump just wouldn't move it. Could the mechanical pump get an air lock or something?
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
Entire Thread
I'm stumped...carb?, fuel pump?, other?.... any ideas???
| hardcrab | 05/18/2013 5:42 PM |
Re: I'm stumped...carb?, fuel pump?, other?.... any ideas???
| Steve_H | 05/18/2013 6:03 PM |
| hardcrab | 05/18/2013 6:12 PM |
| Steve_H | 05/18/2013 6:19 PM |
| Jim Sears | 05/18/2013 11:09 PM |
| carbking | 05/19/2013 8:00 AM |
| don stocker | 05/19/2013 8:10 AM |
| hardcrab | 05/19/2013 8:20 AM |
| hardcrab | 05/19/2013 8:12 AM |
| Anzan | 05/25/2013 11:48 AM |
| sstock | 05/25/2013 12:08 PM |
| brokenhead | 05/25/2013 1:45 PM |
| oldbluetruck | 05/26/2013 1:00 PM |
| Teds58Panel | 05/31/2013 7:38 PM | |
