2 members (RayF, MNSmith),
154
Mod | | | Forums66 Topics128,284 Posts1,058,528 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94400 01/23/2006 12:05 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | magnolia,
To get net on the problem, it's either electrical or mechanical. The brakes and turn signal are a single circuit. Are you saying you have taillights, but no brake lights or backup lights.
The backup lights are not connected directly to the brake circuit...unless they might share a common fuse. After checking fuses, I would crawl around under the truck and look for mechanical damage.
I am not sure the brake light circuit is fused. It is connected to the flasher, and it does go through a switch of some sort.
A inexpensive 12v tester is very handy for problems like this. Grab a wiring diagram for your year truck and see if there is any common denominator between these failed items.
Stuart | | | |
Entire Thread
Signal, brake & reverse lights don't work, running do
| OldBlue58 | 01/22/2006 10:21 PM |
Re: Signal, brake & reverse lights don't work, running do
| atomarc | 01/23/2006 12:05 AM |
| OldBlue58 | 01/23/2006 4:33 AM |
| atomarc | 01/23/2006 5:08 AM |
| 52 Ted | 01/23/2006 9:47 PM | |
