8 members (greenie-reddy, Wayne67vert, 2-Ton, Otto Skorzeny, Gray_Ghost, Greg_H, papas52, WICruiser),
144
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,152 Posts1,056,825 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94300 01/18/2006 4:35 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | runnjump,
Welcome to the site. Although I don't know the answer to your question, I will say that a 100 RPM difference is quite insignificant.
The availability of the proper unit could be a sticky wicket...because this item responds to engine vacuum, the difference must be achieved with the internal spring.
Unless you are attempting to do a matching numbers thing, I don't think you would ever notice the difference between these two vacuum advance units.
Stuart | | |
