| | | Forums66 Topics128,193 Posts1,057,249 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy Bill, I'd really appreceate it if you would check. I haven't been able to find anything online. That's the missing link that's preventing me from making my own fittings once I get electric piped over to the mill.
Yep Dave, all to common. I've found a bunch on my '50 around the rear engine mount crossmember. I might add that whether you weld that crack or not wurlitzer46, you can stop it by drilling a hole at the end of the crack. That should be done even if you do get it welded. Denny G
Denny G Sandwich, IL
Entire Thread
Brake junction block, 1/2 ton?
| wurlitzer46 | 05/11/2013 9:36 PM |
Re: Brake junction block, 1/2 ton?
| Achipmunk | 05/11/2013 10:14 PM |
| GWWirth | 05/11/2013 10:59 PM |
| wurlitzer46 | 05/12/2013 1:12 AM |
| DADS50 | 05/12/2013 6:19 AM |
| wurlitzer46 | 05/12/2013 8:05 AM |
| DADS50 | 05/12/2013 10:38 AM |
| wurlitzer46 | 05/12/2013 9:32 PM |
| Denny Graham | 05/12/2013 7:24 AM |
| Denny Graham | 05/12/2013 9:12 AM |
| tclederman | 05/12/2013 9:53 AM |
| tclederman | 05/12/2013 9:57 AM |
| GWWirth | 05/13/2013 8:07 PM |
| Denny Graham | 05/12/2013 10:37 AM |
| MNSmith | 05/12/2013 10:54 AM |
| Denny Graham | 05/12/2013 11:18 AM |
| LONGBOX55 | 05/12/2013 1:54 PM |
| Pre '68 Dave | 05/12/2013 11:12 PM |
| Denny Graham | 05/13/2013 7:38 AM |
| wurlitzer46 | 05/13/2013 10:17 AM |
| Pre '68 Dave | 05/13/2013 10:50 AM |
| Tiny_Jaime | 05/14/2013 3:31 AM | |
